11-17-2006 03:36 AM - edited 03-05-2019 12:52 PM
Can anyone suggest how to fix valid magic number on 3825.
see the below message
loadprog: error - trouble reading file magic number
boot: cannot load "flash:"
Mahmood
11-17-2006 03:44 AM
did you do anything with flash banks? maybe you put it out and then put in or smth like that?
11-17-2006 03:49 AM
thanks for u r reply.actually the problem is that the ios got corrupted and i upload the new ios using tftpdnld.after that when i reboot it i got this message.any comments.
Mahmood
11-17-2006 03:50 AM
try uploading the flash file again and at the end of the upload do a verfication using the command verify flash:
If this fails too try formatting the flash memory and upload the IOS
HTH, rate if it does
Narayan
11-17-2006 03:55 AM
thanks for your reply.can u suggest me hoe to format the flash.
Mahmood
11-17-2006 11:31 PM
Hi guys
Any update...
Mahmood
11-17-2006 11:48 PM
Go through this link
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis3700/sw_conf/37_swcf/appendb.htm
Narayan
11-18-2006 12:17 AM
Thanks for your reply.but the problem is that i am in rommon so i cannot use this command.any help..
Mahmood
