Invalid magic number on 3825
Can anyone suggest how to fix valid magic number on 3825.
see the below message
loadprog: error - trouble reading file magic number
boot: cannot load "flash:"
Mahmood
Re: Invalid magic number on 3825
did you do anything with flash banks? maybe you put it out and then put in or smth like that?
thanks for u r reply.actually the problem is that the ios got corrupted and i upload the new ios using tftpdnld.after that when i reboot it i got this message.any comments.
Mahmood
try uploading the flash file again and at the end of the upload do a verfication using the command verify flash:
If this fails too try formatting the flash memory and upload the IOS
HTH, rate if it does
Narayan
thanks for your reply.can u suggest me hoe to format the flash.
Mahmood
Hi guys
Any update...
Mahmood
Thanks for your reply.but the problem is that i am in rommon so i cannot use this command.any help..
Mahmood
1007
