IOS 12.2(33)SXI5 known bugs
Rosa Ladeira
I have 4 6509 boxes running Cisco IOS Software, s3223_rp Software (s3223_rp-IPBASEK9-M), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2).
Two of tem have rebooted by itself.
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 22-Oct-10 14:31 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
cat6509-wc1 uptime is 1 day, 7 minutes
Uptime for this control processor is 1 day, 7 minutes
Time since cat6509-wc1 switched to active is 1 day, 6 minutes
System returned to ROM by power on (SP by watchdog NMI at PC 0x409D3EF8, address 0x0)
System restarted at 09:06:26 BRST Tue Mar 6 2012
System image file is "sup-bootdisk:/s3223-ipbasek9-mz.122-33.SXI5.bin"
Last reload reason: Reload Command
I have looked for reasons but I did not find any. Does anybody know what is it ?
Rosa
2 Accepted Solutions
glen.grant
  you would have to get the tac involved and send them a show tech for them to analyze and see if they can see anything.
Leo Laohoo
This is the reason why your supervisor card rebooted.  Don't know what that means, though.
Have you tried SXJ1 or SXJ2?
11 Replies 11
glen.grant
Thanks a lot, but unfortunately we do not have access to tac.
Rosa
Leo Laohoo
Shame on me. I was blind.
But ... why do you have asked me for SXJ1 or SXJ2, if power is the real problem ?
Rosa
Hi Rosa ,
Can you paste a :
remote command switch show version
Dan
cat6509-wc1#show version
cat6509-wc1 uptime is 2 days, 37 minutes
Uptime for this control processor is 2 days, 37 minutes
Time since cat6509-wc1 switched to active is 2 days, 36 minutes
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.4) with 458752K/65536K bytes of memory.
Processor board ID SMG1206N40E
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
3 Virtual Ethernet interfaces
337 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x102
cat6509-wc1#
Watchdog timer isn't a power issue.  It's either a bug or a hardware issue.
You sure you don't have any crashinfo files around?
We have  SXI5  on probably 30 6500's and its been very stable so far .  But ours are Sup 720's and not Sup 32's.
We've moved from SXI5 to SXJ1.  Will be going up to SXJ2 by the end of this month.
just to let you all know, SXI5 has some "ciritical" bugs which can case your boxes to reload. Many of them are fixed in SXI8a, but SXI is still a short-term release. If you wanna have a long-term release move to SXJ.
regards,
Dirk
regards, Dirk (Please rate if helpful)
Hi all ,
One of them is :
CSCtx50235 : 6500 crashes with SP due to RP and RP due to SP
Dan
