10-31-2014 04:10 AM - edited 03-07-2019 09:19 PM
Hi. I have been running two 2960X switches(ver- 15.0(2)EX4) in stack. I need to downrade image to 15.0(2)EX3 due to bug in current image.
I tried below image to download on flash1 & flash2 through "copy tftp flash1" command but it gave error of timed out.
Pls suggest me how could i downgrade image in this scenario.
current image : c2960x-universalk9-mz.150-2.EX4.bin
Downgrade image : c2960x-universalk9-mz.150-2.EX3.bin
Solved! Go to Solution.
10-31-2014 07:08 AM
No, this is not from Rommon mode.
maybe your switch does not come with USB than.
here is an output from a 3850 look at the line before last
test#copy ?
/erase Erase destination file system.
/error Allow to copy error file.
/noverify Don't verify image signature before reload.
/verify Verify image signature before reload.
cns: Copy from cns: file system
crashinfo: Copy from crashinfo: file system
flash: Copy from flash: file system
ftp: Copy from ftp: file system
http: Copy from http: file system
https: Copy from https: file system
logging Copy logging messages
memory Memory debug information
null: Copy from null: file system
nvram: Copy from nvram: file system
onboard no description
processes Active process statistics
rcp: Copy from rcp: file system
running-config Copy from current system configuration
scp: Copy from scp: file system
startup-config Copy from startup configuration
stby-nvram: Copy from stby-nvram: file system
stby-rcsf: Copy from stby-rcsf: file system
system: Copy from system: file system
tar: Copy from tar: file system
tftp: Copy from tftp: file system
tmpsys: Copy from tmpsys: file system
usbflash0: Copy from usbflash0: file system
webui: Copy from webui: file system
In this case you have to use tftp
copy tftp flash1
copy tftp flash2
10-31-2014 04:18 AM
Can you post the output of
dir or dir flash
or "sh flash"
10-31-2014 04:27 AM
Hi Reza..
2960X-SW#dir flash:
Directory of flash:/
2 -rwx 5715 Jun 5 2014 11:31:55 +00:00 express_setup.debug
3 -rwx 4120 Oct 31 2014 09:07:01 +00:00 multiple-fs
4 -rwx 2356 Sep 1 2014 07:45:09 +00:00 vlan.dat
5 -rwx 7248 Jun 21 2014 05:52:16 +00:00 config.text.backup
6 -rwx 1913 Jun 21 2014 05:52:16 +00:00 private-config.text.backup
7 drwx 512 Mar 20 2014 19:25:28 +00:00 c2960x-universalk9-mz.150-2.EX4
646 drwx 512 Mar 20 2014 19:25:29 +00:00 dc_profile_dir
648 -rwx 3819 Oct 31 2014 09:07:01 +00:00 private-config.text
649 -rwx 7439 Oct 31 2014 09:07:01 +00:00 config.text
122185728 bytes total (98678784 bytes free)
2960X-SW#sh flash:
10-31-2014 04:33 AM
Hi.
Ok, so you don't have 15.0(2)EX3 on the flash. If you want to downgrade to 15.0(2)EX3 than you need to download it from Cisco.com first and than load it to the flash via tftp or USB.
10-31-2014 04:39 AM
Hi Reza,
I have downloaded image 15.0(2)EX3 from cisco site. But when i try to download it via tftp "copy tftp flash" it gave error of timed out.
pls tell me how could i download this image in flash on both stack switches.
10-31-2014 04:44 AM
Do you have physical access to the switches? if you do load the IOS into a flash drive and insert it into the USB slot on the switch and copy from USB to flash.
10-31-2014 05:01 AM
I do have physical access of switches but i dont know process of downloading image in switch via USB. Also should i need to insert USB on both switches
Is there any reason of tftp process not working.
10-31-2014 05:13 AM
If you have access to the devices there is no reason to use TFTP. USB is soooo much easier. All you have to do it download the image into the USB insert it into each switch and copy from usb to tftp
10-31-2014 05:45 AM
Hi Reza..
Which command do i need to execute to copy image from usb to flash.
Also since there is single management in stack, how could i copy it on both switches.
10-31-2014 06:34 AM
The command to copy from usb to flash should be something like this
copy usbflash0: flash:<ios name>
for switch-2 it should be usbflash1 and flash1
do a ? after copy it will show you all the options you have.
10-31-2014 06:58 AM
Hi Reza.. Would this above command run in rommon mode since i dont see this option now in switch now.
2960X-SW#copy ?
bs: Copy from bs: file system
flash1: Copy from flash1: file system
flash2: Copy from flash2: file system
xmodem: Copy from xmodem: file system
ymodem: Copy from ymodem: file system
10-31-2014 07:08 AM
test#copy ?
copy tftp flash1
copy tftp flash2
10-31-2014 08:34 AM
Thanks Reza..
