ios aaa and telnet
I have aaa new model configured on a number of isr's(1800, 1900, 2900, 3800 etc).  When i have aaa configured, the telnet logins use that authentication and not the password in the line vty portion.  Is this by design.  would disabling aaa enable both telnet and aaa authentications, essentially making it a dual login.
ios aaa and telnet
This is by design. AAA authentication takes precedence. You won't be able to get a default login because once you enable AAA, it immediately asks for a username to authenticate with.
HTH, John *** Please rate all useful posts ***
Purple
ios aaa and telnet
aaa authentication login default line  should give the default login with aaa enabled but not both as you said.
Regards.
Alain.
ios aaa and telnet
Alain....rated. I've never used that one, but it works...
211
