Silver
IOS and Boot Loader
Hello Pros,
The show version output shows the IOS is:
Cisco IOS Software, C3750E Software (C3750E-UNIVERSAL-M), Version 12.2(44)SE1, RELEASE SOFTWARE (fc1)
but the Boot Loader is:
BOOTLDR: C3750E Boot Loader (C3750E-HBOOT-M) Version 12.2(35r)SE1, RELEASE SOFTWARE (fc2)
Would this be possible that the Boot Loader to be different thant the IOS?
Here's the output of the "sh boot" command after the upgrade:
3750#sh boot
BOOT path-list : flash:c3750e-universal-mz.122-44.SE1/c3750e-universal-mz.122-44.SE1.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
Timeout for Config
Download: 0 seconds
Config Download
via DHCP: disabled (next boot: disabled)
Switch 2
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : no
Auto upgrade path :
Switch 4
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : no
Auto upgrade path :
Switch 5
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : no
Auto upgrade path :
1 REPLY
Hall of Fame Super Silver
Re: IOS and Boot Loader
Bahman
Yes it is possible for the bootloader to be a different version than the image file. This does not cause a problem.
Rick
625
