10-14-2008 10:31 AM - last edited on 03-25-2019 04:03 PM by ciscomoderator
Where can I find a doc that told me what IOS is compatible with my hardware?
To explain the situation: My custumer has a C6513 with 12.2(17d)SXB11 IOS, He plugged a WS-X6148A-GE-TX card and some error messages appear.
By the output interpreter, I found a solution (unsupported module in slot), but I would like a doc that says that IOS is not compatible with the card or vice versa.
PS.: The WS-X6148A-GE-TX's datasheet doesn't give me this information.
Solved! Go to Solution.
10-14-2008 10:37 AM
The release notes are the place to look. As an example attached are release notes for native IOS 12.2SXF.
If you open the link and then search for WS-X6148A-GE-TX it will go that module - left hand box and then it will tell you the minimum IOS needed - in this case 12.2(18)SXF for sup32 and sup720 and 12.2(18)SXF2 for sup2.
Here is also the link for all 6500 release notes -
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_release_notes_list.html
Jon
10-14-2008 10:37 AM
Jon
