IOS Commands analogous to CatOS
Hi all,
Maybe there is no real one to one correlation but I wanted to know once you had the right privilege what the IOS commands were for the following CatOS commands:
set port en 2/1
set vlan 1 2/1
set port sec 2/1 en
set port sec 2/1 violation shutdown
set port sec 2/1 shutdown 5.
Thanks all.
Re: IOS Commands analogous to CatOS
Here are the commands,
AAASWITCH(config)#interface fastEthernet 0/1
AAASWITCH(config-if)#no shutdown
AAASWITCH(config-if)#switchport mode access
AAASWITCH(config-if)#switchport access vlan 1
AAASWITCH(config-if)#switchport port-security violation shutdown
jgambhir thank you for teh superfast response.
just one more question:
Is there anyway to set the violation shutdown time to 5 minutes?
I dont think this command is there in IOS. You need to manually no shut the interface.
~JG
Please rate helpful posts
JG thanks for all your help.
I'll probably post this as a separate topic to get some more input.
209
