Webcast-Catalyst9k
IOS Crashed with Error message: System was restarted by bus error at PC 0x5CE650, address 0x0
Hi Guys,
I've IOS Crashed with Error message: System was restarted by bus error at PC 0x5CE650, address 0x0
Switch model: WS-C2960-24TC-L
Switch IOS version: 12.2(44)SE1
Switch IOS Image: C2960-LANBASE-M
Logs file results:
Dec 3 16:48:42: %PLATFORM-1-CRASHED: System previously crashed with the following message:
Dec 3 16:48:42: %PLATFORM-1-CRASHED: Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(44)SE1, RELEASE SOFTWARE (fc1)
Dec 3 16:48:42: %PLATFORM-1-CRASHED: Copyright (c) 1986-2008 by Cisco Systems, Inc.
Dec 3 16:48:42: %PLATFORM-1-CRASHED: Compiled Thu 06-Mar-08 21:11 by weiliu
Dec 3 16:48:42: %PLATFORM-1-CRASHED: Data Access Exception (0x0300)!
Dec 3 16:48:42: %PLATFORM-1-CRASHED: SRR0 = 0x005CE650 SRR1 = 0x00029230 SRR2 = 0x0054C77C SRR3 = 0x00021200
Dec 3 16:48:42: %PLATFORM-1-CRASHED: ESR = 0x00800000 DEAR = 0x0001B824 TSR = 0x84000000 DBSR = 0x00000000
Dec 3 16:48:42: %PLATFORM-1-CRASHED: CPU Register Context:
Dec 3 16:48:42: %PLATFORM-1-CRASHED: Vector = 0x00000300 PC = 0x005CE650 MSR = 0x00029230 CR = 0x24444028
Dec 3 16:48:42: %PLATFORM-1-CRASHED: LR = 0x005CE644 CTR = 0x00A33E94 XER = 0x60000050
Dec  3 16:48:42: %PLATFORM-1-CRASHED: R0 = 0x3863BED8 R1 = 0x01B266F0 R2 = 0x00000000 R3 = 0x00000000
Dec 3 16:48:42: %PLATFORM-1-CRASHED: R4 = 0x01DC0214 R5 = 0x008573BC R6 = 0x01AE124C R7 = 0x00000000
Dec 3 16:48:42: %PLATFORM-1-CRASHED: R8 = 0xD0000000 R9 = 0x00000000 R10 = 0x01AE0D60 R11 = 0x00000000
Dec 3 16:48:42: %PLATFORM-1-CRASHED: R12 = 0x9862A7A8 R13 = 0x00110000 R14 = 0x00000000 R15 = 0x00000000
Dec 3 16:48:42: %PLATFORM-1-CRASHED: R16 = 0x0193FCFC R17 = 0x0193FCC4 R18 = 0x01940000 R19 = 0x01830000
Dec 3 16:48:42: %PLATFORM-1-CRASHED: R20 = 0x0193FCFC R21 = 0x00000000 R22 = 0x01940000 R23 = 0x00000000
Dec 3 16:48:42: %PLATFORM-1-CRASHED: R24 = 0x00000060 R25 = 0x015D68C0 R26 = 0x00021200 R27 = 0x00000001
Dec 3 16:48:42: %PLATFORM-1-CRASHED: R28 = 0xD6CD57F7 R29 = 0x0054BC00 R30 = 0x00000000 R31 = 0x00000000
Dec 3 16:48:42: %PLATFORM-1-CRASHED: Stack trace:
Dec 3 16:48:42: %PLATFORM-1-CRASHED: PC = 0x005CE650, SP = 0x01B266F0
Dec 3 16:48:42: %PLATFORM-1-CRASHED: Frame 00: SP = 0xFFFFFFFF   PC = 0x005CE63C
Stacks results:
Minimum process stacks:
Free/Size   Name
5104/6000   hulc_flash init
3616/6000   SaveCrashBuffer
5740/6000   CDP BLOB
5628/6000   DHCPD Receive
5572/6000   stp_change_tree_type
5656/6000   vqpc_shim_create_addr_tbl
5636/6000   SPAN Subsystem
5584/6000   SASL MAIN
5572/6000   hpm bulk_vlan_state process
8808/12000 Init
8724/9000   cdp init process
5480/6000   RADIUS INITCONFIG
5620/6000   Hulc Backup Interface Process
4940/6000   HULC CrashBuffer
2600/3000   Rom Random Update Process
35132/36000 TCP Command
9212/12000 Virtual Exec
Interrupt level stacks:
Level   Called Unused/Size Name
4 3596032885   8464/9000 NETWORK INTERFACE CHIP
5           0   9000/9000 SUPERVISOR EXCEPTIONS
6         40   8932/9000 NS16550 VECTOR
Compiled Thu 06-Mar-08 21:11 by weiliu (current version)
Image text-base: 0x00003000, data-base: 0x01000000
Stack trace from system failure:
FP: 0x1B266F0, RA: 0x5CE650
FP: 0xFFFFFFFF, RA: 0x5CE63C
******* Information of Last System Crash **********
Using flash:/crashinfo/crashinfo_2.
Stack trace:
could you please help me to know the reason for this IOS crashed.
Kamel
2 ACCEPTED SOLUTIONS
VIP Purple
HI Kamel,
Leo is right, you must upgarde ur IOS,
Error:
A bus error generally means that the CPU tried to access a memory location that is not physically accessible. In most cases, this is a problem of the operating system.
Your IOS is very old.Please update it.
Regrds
Hall of Fame Super Gold
I want to ask about the reasone for this IOS crashed, do you have any idea?
You'll need to create a Cisco TAC case and submit to them the "sh tech-support" so they can determine what caused the crash and the Bug ID.
Your IOS is old.  Your IOS is also known to be buggy, particularly when you are running SE1.
Upgrade to either 15.0(2)SE4 or 12.2(55)SE8.
Thanks Leo,
VIP Purple
HI Kamel,
Error:
Regrds
Thanks a lot sandeepchoudhary
VIP Purple
Re: IOS Crashed with Error message: System was restarted by bus
Thanks for rating.
Can u please mark this question as answered, it may help others.
Thanks a lot Leo, I'll try to create a Cisco TAC case
911
