IOS Deleted from a WS-C2948G
Hi All,
I deleted the IOS from the bootflash: thinking i was going to be able to load one from xmodem or tftp via rommon. I have tried for a while now with no luck..im begining to think its not possible in this platform? Can someone please help, thanks!!!
  • LAN Switching and Routing
Re: IOS Deleted from a WS-C2948G
Hi Friend,
You can use Xmodem/TFTP from rommon to recover the switch. Here is a document with the procedure listed.
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00800949c3.shtml#cat4k_rec
HTH.
-amit singh
Thank you so much ...i was able to get the switch back up and running.
Thanks AGAIN!
Silver
Hi ,
Below link gives step by step procedure how to recover 2948G after deleting ios.
http://www.cisco.com/en/US/partner/products/hw/switches/ps663/products_tech_note09186a00800949c3.shtml#cat4k
Hope it helps you.
satish
I've had to do this once. The procedure was a bit misleading. Here's what I learned:
First on the switch type:
switch: copy xmodem: flash:xxxIOSxxxx.bin
You'll see something like:
CCC..............
(This has now become "Beat the Clock")
Now in Hyperterminal execute the file transfer from the send..... menu.
Hope this helps!
385
