IOS Licence: 3750 Switch
t4tauseef33
I have purchased the cisco 3750 switch from cisco retailter that comes with the IP base image. I want to upgrade it to IP services image to have more functionality. Does it require to purchase the licence? I have the CCO account and can download the Ip services image from cisco website but i am not sure its legal or not? your help will be appriciated.
Collin Clark
You do need to purchase the Enhanced Multilayer Software Image license to legally run it. If you can provide the exact model (post a show version), we can get you the part number to order.
Hope that helps.
Can you please tell me for which IOS versions i have to pay the licence?
Switch-01#sh ver
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(25)SEE4, REL EASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 16-Jul-07 03:24 by myl
Image text-base: 0x00003000, data-base: 0x01040000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SE1, RELEASE SOFTWAR E (fc)
Switch-01 uptime is 1 year, 9 weeks, 6 days, 1 hour, 55 minutes
System restarted at 12:30:49 GMT Tue Apr 15 2008
System image file is "flash:c3750-ipbasek9-mz.122-25.SEE4/c3750-ipbasek9-mz.122- 25.SEE4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-48PS (PowerPC405) processor (revision C0) with 118784K/12280K by tes of memory.
Processor board ID FOC1003Z35J
Last reset from power-on
5 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:16:C8:0B:18:00
Motherboard assembly number : 73-9365-08
Power supply part number : 341-0108-02
Motherboard serial number : FOC10023FCN
Power supply serial number : DCA10010148
Model revision number : C0
Motherboard revision number : A0
Model number : WS-C3750G-48PS-S
System serial number : FOC1003Z35J
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT09532DH4
Top Assembly Part Number : 800-25408-02
Top Assembly Revision Number : B0
Version ID : V02
CLEI Code Number : CNMWN00ARB
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750G-48PS 12.2(25)SEE4 C3750-IPBASEK9-M
Configuration register is 0xF
The part number is CD-3750G-48EMI=
Note that your SMARTNet Maintenance will change. Below are the options and part numbers (part #'s are in parenthesis).
SMARTNET 24X7X2 Cat 3750 48 10/100/1000T PoE + 4 SF (CON-S2P-3750GPE) 24x7x2
ONSITE 24X7X4 Cat 3750 48 10/100/1000T PoE + 4 SF (CON-OSP-3750GPE) 24x7x4
ONSITE 8X5X4 Cat 3750 48 10/100/1000T PoE + 4 SF (CON-OSE-3750GPE) 8x5x4
SMARTNET 24X7X4 Cat 3750 48 10/100/1000T PoE + 4 SF (CON-SNTP-3750GPE) 24x7x4
SMARTNET 8X5X4 Cat 3750 48 10/100/1000T PoE + 4 SF (CON-SNTE-3750GPE) 8x5x4
ONSITE 8X5XNBD Cat 3750 48 10/100/1000T PoE + 4 SF (CON-OS-3750GPE) NBD AR
SMARTNET 8X5XNBD Cat 3750 48 10/100/1000T PoE + 4 SF (CON-SNT-3750GPE) NBD AR
