IOS migration from 12.3 to 12.4
bugneac2
Hi!
I am using currently IOS 12.3.22GD release (c3660-jk9o3s-mz.123-22.bin) on Cisco3662AC router.
How can I select the right IOS from 12.4 with the same features?
ankbhasi
Hi Friend,
The latest in 12.4 release is 12.4(13) and the feature set which you are running is
Enterprise/FW/IDS PLUS IPSEC 3DES
And the release i,age will be "c3660-jk9o3s-mz.12.4-13.bin " not sure if its a GD release in 12.4 train.
Also it required DRAM / Min Flash 128 / 64
To check for more releases you can use Feature navigator tool
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Ankur
*Pls rate all helpfull post
