IOS selection
I have several 3560's, 3550's, 2950's and 2924's. They are all on different feature set even though they all do the same job. The only difference is that some have poe ports and some dont.
c3560-i9-mz.122-20.SE4.bin
c3560-ipbase-mz.122-25.SEE3.bin
c3550-i9q3l2-mz.121-8.EA1c.bin
c2950-i6q4l2-mz.121-22.EA4a.bin
c2900xl-c3h2s-mz.120-5.WC9.bin (2924)
I was wondering if anyone can recommend one or even two (one for poe and one for non poe) feature set that I can use for all off my switches.
1 REPLY
Hall of Fame Super Bronze
Re: IOS selection
I recommend going to http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp and make the decision that fits your network better.
Input your current image and compare with an intended image for features that you will gain/lose when doing the migration.
396
