Community Member
IOS up gradation error - urgent
I am getting error while trying to upgrade the IOS of Cisco 3560 switch.Please find the attached screen shot for the error message and show version command output.We have total 7 3560 switch and I am getting the same problem for all.I have used the same TFTP server for up gradation of both firewall and router and I didn't get any error.
Please help to resolve it..
1 ACCEPTED SOLUTION
Community Member
Re: IOS up gradation error - urgent
Hi Somnath
It looks like you don't have problem with swithes.This problem seems to be with your TFTP application.
Try any of the following steps.
1)Please reboot your computer and then start the TFTP application and try to upgrade the IOS....it should work now..if not go to next step.
2)Re Install the TFTP application and follow step 1
3)Or you can download the Free Solarwind TFTP application http://www.solarwinds.com/products/freetools/free_tftp_server.aspx and use it to upgarde the IOS.
Cheers (rate it if it helped you to resolve the issue)
Community Member
hi
once i faced same problem. i installed another tftp server in my pc and it was working. try changing tftp server.
hope this will help.
Community Member
Hi Somnath
Community Member
Thanks!! with Solarwind TFTP application I have done it sucessfully.
Now I have two IOS in switch.Please find the details given below...
INHYDAGL-SW-06#sh boot s
flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin
INHYDAGL-SW-06#sh flas
INHYDAGL-SW-06#sh flash:
Directory of flash:/
2 -rwx 1096 Sep 22 2008 10:23:06 +05:30 vlan.dat
3 drwx 128 Apr 11 1993 21:42:46 +05:30 crashinfo_ext
417 -rwx 10609 Sep 19 2008 10:39:27 +05:30 config.text
5 -rwx 27 Sep 19 2008 10:39:27 +05:30 private-config.text
6 drwx 192 Mar 2 1993 12:41:25 +05:30 c3560-ipbase-mz.122-25.SEE2
410 drwx 256 Mar 1 1993 05:32:32 +05:30 crashinfo
414 -rwx 7010856 Mar 18 1993 01:34:28 +05:30 c3560-ipbasek9-mz.122-25.SEE4.bin
32514048 bytes total (17249792 bytes free)
BOOT path-list : flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
INHYDAGL-SW-06#
I want boot the switch with "c3560-ipbasek9-mz.122-25.SEE4.bin" and delete previous one..wht are the commands I need to give for that...
Community Member
Go to configure terminal
#Conf t
#no boot system flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin
#boot system flash:c3560-ipbasek9-mz.122-25.SEE4.bin
#copy running-config startup-config
#Reload
--After Reboot run show version and check if Switch is booted with new image.
--Once everything is working
#delete flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin
#squeez flash
you are good to go.....
135
