IOS upgradation WS-C3750G-48TS-S
lerner cisco
All,
I am planning to upgrade IOS at  WS-C3750G-48TS-S   ,I copied IOS  checked the md5 all looking good , however  when I check  " show boot " I am getting below logs for the existing IOS  , to load new IOS  that is c3750-ipservicesk9-mz.122-58.SE2.bin    I am plan to issue below command , please suggest it works or not  or creates some issue
   no boot system
   boot system flash:c3750-ipservicesk9-mz.122-58.SE2.bin
  Existing booth system  showing like  " flash:flash:/c3750-ipservicesk9-mz.122-37.SE.bin  "
switch#sh boot
BOOT path-list   : flash:flash:/c3750-ipservicesk9-mz.122-37.SE.bin
switch#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(37)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
System image file is "flash:/c3750-ipservicesk9-mz.122-37.SE.bin"
It may not change until you reboot:
do a:
no boot system flash:c3750-ipservicesk9-mz.122-37.SE.bin
and then
save and reboot.
Reza Sharifi
On the 3750s you can only have one boot statement.
so add
save and reboot.  It should boot and load the new image.  Make sure you have a copy of the old image saved somewhere.
thank you
the old image still at  same flash , I am wondering  why existing switch showing "sh boot " weird
switch#sh boot
do a:
and then
save and reboot.
