IOS upgrade for ME3800 and license
I am planning to upgrade an ME3800 switch with IOS ( flash:/me380x-universal-mz.122-52.EY3/me380x-universal-mz.122-52.EY3.bin) to a new version. curruntly the switch has MetroIPServices activated. I downloaded the new version from the cisco web site  (me380x-universalk9-tar.153-1.S.tar)
Do i need to backup the currrntly installed license before the upgrade? or the license will be kept when i upgrade to the new version?
The current IOS is without crypto, can i upgrade to a new version with crypto?
Best regards,
Anas
VIP Super Bronze
Hi Anas,
I have never use the ME3800 series, but have other switches e.g 3560, 3750, etc.. For all these models you only install the license once and when you upgrade the IOS the license does not need to be backed up or reinstalled.  I would think, it is the same with 3800ME.
Hi Reza,
ME3800/ME3600 and i belive the 3560X comes with universal image and there are licenses to upgrade from feature to feature. the installed feature in my ME3800 is a MetroIPServices, I dont know if i upgrade to the new version, i should migrate the license to the new IOS?
Hall of Fame Super Gold
When you upgrade the IOS, your license will be un-touched.
VIP Super Bronze
As I noted, with 3560X, 3750X switches when you upgrade the IOS, you don't do anything with license. It stays the same regardless of the version of IOS. So for example: if you have IOS 15.1 with IP Services license and you upgrade to 15.2, the license is still the same.
Reza
Thank you
241
