IOS upgrade to AP
ney25
Level 2
Level 2
Hi Netpro,
anyone can help me about this ? i can't upload my IOS to AP.
AP01#dir
Directory of flash:/
2 -rwx 714 Mar 1 2002 08:00:07 +08:00 env_vars
7 drwx 512 Jan 14 2006 16:48:58 +08:00 c1200-k9w7-mx.123-7.JA1
3 -rwx 27 Jul 29 2007 12:35:34 +08:00 private-config
5 -rwx 4955 Jul 29 2007 12:35:34 +08:00 config.txt
6 -rwx 1048 Jul 29 2007 12:35:34 +08:00 private-multiple-fs
7741440 bytes total (2812416 bytes free)
AP01#dir c1200-k9w7-mx.123-7.JA1
Directory of flash:/c1200-k9w7-mx.123-7.JA1/
8 drwx 64 Jan 14 2006 16:34:32 +08:00 html
145 -rwx 3680688 Jan 14 2006 16:47:25 +08:00 c1200-k9w7-mx.123-7.JA1
146 -rwx 131328 Jan 14 2006 16:47:51 +08:00 5001.img
147 -rwx 131328 Jan 14 2006 16:47:54 +08:00 5101.img
148 -rwx 131328 Jan 14 2006 16:48:33 +08:00 6301.img
149 -rwx 131328 Jan 14 2006 16:48:37 +08:00 6701.img
150 -rwx 131328 Jan 14 2006 16:48:58 +08:00 6701_cal.img
151 -rwx 274 Jan 14 2006 16:48:58 +08:00 info
AP01#copy tftp flash:/c1200-k9w7-tar.123-8.JA2/c1200-k9w7-tar.123-8.JA2.tar
Address or name of remote host [172.17.62.71]?
Source filename [c1200-k9w7-tar.123-8.JA2.tar]?
Destination filename [/c1200-k9w7-tar.123-8.JA2/c1200-k9w7-tar.123-8.JA2.tar]?
Accessing tftp://172.17.62.71/c1200-k9w7-tar.123-8.JA2.tar...
%Error opening tftp://172.17.62.71/c1200-k9w7-tar.123-8.JA2.tar (Permission denied)
regards,
Jackal
2 Accepted Solutions
Amit Singh
Jackal,
You are using a wrong procedure to upload the IOS on the AP. You are using a .tar file and this will not work with the normal " copy" command. You have to extract this .tar file to use the files which are inside this zipeed file. You have to use the following command:
archive download-sw /overwrite /reload tftp://172.17.62.71/c1200-k9w7-tar.123-8.JA2.tar
Please use the link below for more understanding:
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_8_JA/configuration/guide/s38mfw.html#wp1035507
HTH,please rate if it does.
-amit singh
though above post from asingh2 is at place.
Kindly check your tftp application setings that its enabled for transmit/receive as there erro showing "permission denied+ after accessing the tftp server.
Thanks EM
kindly rate all post if it helps.
Amit Singh
Jackal,
-amit singh
Thanks EM
I think the error that we are getting " error opening file" is probably because AP is not able to open and copy the file to the flash as it is a .tar file and a .tar file cannot be exatracted/opened using a copy command. The " archieve " command is the one which will work here.I believe that there is nothing wrong with the TFTP, probably its the command access for using the file.
-amit singh
I Have a problem, trying to upgrade My AP 1120B from 12.2(13)JA2 to 12.3.8-JA2(ED).
I followed the link listed before. But I have a problem with the tftp Server. The tftp Solaris SERVER says that archive does not exist.
Inside the AP:
error opening tftp://10.0.0.2/c1100-k9w7-tar.123-8.JA2(No such file or directory).
I have configured correctly the tftp server because doing the same task with other routers it works perfectly.
If some one can help me.
thanks.
