11-03-2016 03:24 AM - edited 03-08-2019 08:02 AM
Dear Sir,
I am trying to copy IOS image to Cisco 4503-E switch via tftp in ROMMON mode as someone removed image from the flash.when i check rommon commands there is no xmodem or copy commands there.,so i went with tftp.The connection between the switch and my laptop ok.
So I use following command to transfer image to flash,
rommon>boot tftp://10.0.0.1/filename.bin
but there is error called "tftp session failed: Access violation " ,. I disable windows firewall and tried several times.
I mentioned the set command output below.
rommon> set
PS1=rommon! >
ConfigReg=0x0102
Rommonver=15.0(1r)SG2
IpAddr=10.0.0.1
Netmask=255.0.0.0
Broadcast=10.255.255.255
Gateway=10.0.0.254
BootedFilename=tftp://10.0.0.2/ios.bin
(My image is file in the root directory of tftp server)
Please I kindly ask you to help me as soon as possible .
Thanks in Advaned
11-03-2016 03:55 AM
the syntax looks abit off compared to the docs for rommon tftp , have you tried the below way instead ?
rommon 11 > IP_ADDRESS=192.168.1.5
rommon 12 > IP_SUBNET_MASK=255.255.255.0
rommon 13 > DEFAULT_GATEWAY=192.168.1.1
rommon 14 > TFTP_SERVER=192.168.1.10
rommon 15 > TFTP_FILE=c1841-advipservicesk9-mz.124-13a.bin
rommon 16 > tftpdnld
IP_ADDRESS: 192.168.1.5
IP_SUBNET_MASK: 255.255.255.0
DEFAULT_GATEWAY: 192.168.1.1
TFTP_SERVER: 192.168.1.10
TFTP_FILE: c1841-advipservicesk9-mz.124-13a.bin
TFTP_MACADDR: 00:13:80:7b:20:1e
TFTP_VERBOSE: Progress
TFTP_RETRY_COUNT: 18
TFTP_TIMEOUT: 7200
TFTP_CHECKSUM: Yes
FE_PORT: 0
FE_SPEED_MODE: Auto Detect
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n: [n]: y
Receiving c1841-advipservicesk9-mz.124-13a.bin from 192.168.1.10 !!!!!!!!!!!!!!!
File reception completed.
Validating checksum.
Copying file c1841-advipservicesk9-mz.124-13a.bin to flash.
program load complete, entry point: 0x8000f000, size: 0xc100
Initializing ATA monitor library.......
Format: Drive communication & 1st Sector Write OK...
Writing Monlib sectors.
Monlib write complete
Format: All system sectors written. OK...
Format: Operation completed successfully.
Format of flash: complete
rommon 17 >
11-03-2016 01:06 PM
Dear Mr.Mark,
Thank you very much for your reply.
The switch is cisco 4503-E , there is no " tftpdnld " commnad in this switch.So i use set command to configure ip address .,aslo xmodem is not available.
11-06-2016 02:09 AM
11-06-2016 12:12 PM
Use TFTPDNLD in Rommon
With the appearance of USB ports and SD card slot, xModem & TFTPdnld are old school and very slow.
11-06-2016 09:16 PM
I agree with you Leo . I just wanted to talk about "How to use TFTPDNLD"
BTW, Leo could you participate in my topic please ( Core switch selection ).
11-03-2016 04:05 AM
ConfigReg=0x0102
This value is incorrect.
Connect a console cable to the supervisor card and reboot. I want to see the entire boot-up process, including the error messages.
11-03-2016 01:00 PM
11-03-2016 02:23 PM
Hmmmm ... Look at the error message in the TFTP screenshot: Directory name is invalid.
And, WTF!, the supervisor card is a Sup7E. Aside from the archaic method of uploading an IOS using TFTPdnld or xModem, the line card as a USB port and a SD card slot.
The IOS can be loaded using either USB port of SD card slot.
11-06-2016 02:02 AM
Dear Mr.Leo,
As you said I was trying to boot from USB .MY flash drive was detected and when i execute the command ,
rommon>boot usb0:filename.bin
there is an error massage called file has bad magic number.Then i thought the issue with my ios , i tried with another LAN base ios also but the same problem .The IOSs are not corrupt . I attached screen shot and hope your kind reply again.
11-06-2016 12:11 PM
"Bad magic number" means the file is corrupt.
Go to the Cisco website and compare the MD5 hash value of the file downloaded against the MD5 hash value found in the Cisco website. Both values must match.
11-06-2016 12:17 PM
Thank you very much Mr.Leo
I will try again tomorrow .
12-16-2016 10:13 PM
Thank you very much .
