Webcast-Catalyst9k
IP access restriction in 3560
Hi everybody,
I am configuring 3560 switch. I have the basic requirement. I want to configure a swithc port fa 0/0 to allow only the IP address 192.168.1.1 for example and deny any other PCs with IP address other than this.
I want to retain the port fa 0/0 as switch port only. I know to donot want to configure mac ACL. Can you guide me how to achieve this.
RK
1 ACCEPTED SOLUTION
Purple
Re: IP access restriction in 3560
If u r sure that the switchport will not change for this PC u can use port security to achieve this.
switchport port security
switchport port security mac-address sticky
etc.
Mahmood
Hi Mahmood,
Thanks for reply.
But I suppose that switchport port security mac-address sticky is for MAC address and not for IP address attached to the port.
Can you pl. explain how this command help in my scenario
RK
you can set static ip on your pc and use Mahmood's scenario
Your idea is good, but "mac-address sticky" will check the MAC address associated with the ports & donot care about the IP address of the server connected.
I can very well use either port ACL. But want to know any other alternative solution similar to port security "mac-address sticky "
Purple
119
