Webcast-Catalyst9k
ip accouting in 3750 switch
hi all ,
Is ip accouting is supported on the cisco 3750 swiitch? coz i m not getting any output in show ip accouting command .
Thanks!
Vijay
1 ACCEPTED SOLUTION
VIP Purple
Re: ip accouting in 3750 switch
HI Vijay,
as per this document:
Unsupported Commands in Cisco IOS Release 12.2(53)SE2
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_55_se/configuration/guide/swuncli.html
this command is not supported .
you can see the all commands which are not supported on your catalyst..
Hope it helps.
It does work on my 3750 running ip services IOS
3750-switch#sh run int fa 1/0/1
Building configuration...
Current configuration : 175 bytes
interface FastEthernet1/0/1
no switchport
ip address #.#.#.# #.#.#.#
ip accounting output-packets
speed 100
duplex full
end
3750-switch#sh ip account
   Source           Destination              Packets               Bytes
#.#.#.#              #.#.#.#                           151               12684
#.#.#.#              #.#.#.#                              9                 709
#.#.#.#              #.#.#.#                              9                1260
#.#.#.#              #.#.#.#                            10                1407
Accounting data age is 3
Hi Serge Amos ,
Could u plz tell the model of the switch and version of IOS ??
cisco WS-C3750-48TS
c3750-ipservices-mz.122-50.SE1.bin
VIP Purple
HI Vijay ,
Whcih version of IOS u r running on catalyst
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swuncli.html#wp1060469
Unsupported Interface Configuration Commands
ip accounting
ip load-sharing [per-packet]
ip mtu bytes
ip verify
ip unnumbered type number
All ip security commands
Hope it helps.
Hi sandeep ,
I am using
:c3750-ipservicesk9-mz.122-53.SE2.bin
VIP Purple
HI Vijay,
Hope it helps.
164
