ip address listing in catalyst 6500 series
saravanababu22
pls let me know the command for listing all the ip address in catalyst 6500 series command.
regards
Sara
n.nandrekar
Level 4
Level 4
Hi!
"sh ip int brief" should give you a list of all the interfaces with ip address and thus all the ip addresses configured on the switch.
or you could even use " sh run | i address"
Niranjan
Its cat OS.
This particular works in IOS only.
regards
Sara
Then it will only have one....
CatOS is Layer-2 only, the only IP a CatOS device will have is for management. The command 'show interface' will show you the IP address of the SC0 interface.
If the 6500 is performing routing then it will have an MSFC and this will be running independant IOS (Hybrid Mode). The command 'show ip interface brief' will list each of the IP addresses configured on the SVI interfaces as the previous poster said.
Andy
