Community Member
IP based Quality of Service
I wan't to configure my Catalyst 3750.
My network is: 10.1.0.0 /16
There 4 different sections
1. 10.1.1.0 - 255 for Server's
2. 10.1.100.0 - 255 for IPMI Interface's
3. 10.1.2.0 - 255 for Client's (1)
4. 10.1.3.0 - 255 for Client's (2)
I have created 4 ACL's
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 2 permit 10.1.100.0 0.0.0.255
access-list 3 permit 10.1.2.0 0.0.0.255
access-list 4 permit 10.1.3.0 0.0.0.255
and 3 class-map's
class-map match-any remote
match access-group 1
match access-group 2
exit
class-map match-all software1
match access-group 3
exit
class-map match-all software2
match access-group 4
exit
and 1 policy-map
policy-map marker
class remote
set ip dscp 1
exit
class software1
set ip dscp 2
exit
class software2
set ip dscp 3
exit
I have add the policy-map to any Interface of the switch, because later I wan't that the clients
interface ....................
service-policy input marker
Now, all packets from the definied "areas" of my network are marked with a specific dscp value. But who can I configure Queues that match on the different dscp values?
My goal is that the Packets from Client's (1) always have 60% of the whole bandwidth guaranteed, Packets from Client's (2) 30%, and Packets from Server and IPMI 10% together. I also wan't, when the Client's(1) don't send packets, the other Applications(Server, IPMI, Client's(2)) have the full bandwidth and not only 30% or 10%. Clearly bandwidth guarantee and not a limitiation.
I hope you understand my question.
regards
peterderk
Everyone's tags (1)
1 REPLY
Community Member
Re: IP based Quality of Service
Oh there is a problem. When I give an interface the policy map then pop up a error.
QOSMGR-4-CLASS_NOT_SUPPORTED
That means, only one match per class-map is supported !
When I erase one of the entrys in class-map remote like:
Then is all Ok and the error are not pop up.
Inside the 3750 are only 2 Queues for QoS, but I need 4 different settings. Has anybody a Ideafor a solution?
regards
440
