07-18-2013 12:39 AM - edited 03-07-2019 02:28 PM
hello all,
what is the difference between an ip base and a lan based layer 3 switch?
what is ip based? how does it work?
what is lan based? how does it work?
thanks
07-18-2013 12:42 AM
Please point out where in Cisco documents you have seen these terms.
07-18-2013 12:48 AM
http://www.3anetwork.com/cisco-catalyst-3560-switches-price_c40
i was just wondering what is ip based and ip lan based switch
07-18-2013 12:59 AM
07-18-2013 01:18 AM
These are different IOSes that have different sets of commands and features available. You should check, what kind of image do you need for your purposes. Try to use some of these tools:
http://tools.cisco.com/ITDIT/CFN/
Best regards,
Jan
