06-11-2009 08:44 PM - edited 03-06-2019 06:13 AM
I have A,B,C IP'Sin a vlan.I want to block communication between A and B,C only .Is it possibel.As A is firewall and B,C are ISA servers.I found that while communication B and C my firewall A gets 100% utilized.Communication is passing through firewall A.
06-11-2009 09:05 PM
Put B and C in a separate VLAN and prune the allowed VLAN.
06-11-2009 09:11 PM
Thanks for reply.
Is it not possible to block communication in that devices living in same vlan.
B,C shouldnot communicate to A but to all , living in same vlan ?
06-11-2009 09:33 PM
You can block with IP but do you have a Layer 3 switch or a router?
06-11-2009 09:51 PM
I have 6500 as core , but as this communicaiton should be only L2 then why B,C trying to communicate through my firewall A.B,C are on same switch whereas A is on different switch but all are in same VLAN.
06-12-2009 12:42 AM
If you want to filter traffic inside a VLAN, than you need to use a VLAN map and a VLAN filter
06-12-2009 06:25 AM
hi,
try configuring Private Vlans could help
rgds/shiva
06-12-2009 12:52 AM
There are 2 ways u can do this,one is to use private vlan(use isolated vlan for firewall) and another is use vlan access map.i think vlan access map is easiest to do.create VACLS and apply it to your vlan globally.
06-12-2009 05:46 AM
Please tell us: are A, B and C in the same IP subnet?
If yes
* B must reach C directly, and should not use A.
* Check the ip subnet masks on both A, B and C.
If not
* You will need a L3 device to route between B a C. If this L3 device is your firewall, you can't block communication between A and B,C.
Paulo Roque
06-12-2009 05:52 AM
they are in same subnet.subnet configure correctly.B and C are Server , they need to communicate , but this communication is affecting the Firewall A.This should not happen at switch level.Once switch know where is B and c it should send directly traffic on that port.
06-12-2009 07:10 AM
Hi gajanangavli,
This is my point! If they are in the same IP subnet, there is no reason for they interfere with or use the firewall. If they are interfering with the firewall there is something weird here. Again check the subnet masks in all devices.
