09-18-2014 01:18 AM - edited 03-07-2019 08:47 PM
Dear All,
I have configured DHCP on L3 switch for the VLAN on my LAN. When the users connect an IP conflict error appears and then users are able to obtain the IP address and connect.
Request your kindly suggestion to stop this error from appearing.
My DHCP configuration is as below
ip dhcp excluded-address 192.168.210.1 192.168.210.31
ip dhcp excluded-address 192.168.210.160 192.168.210.254
ip dhcp pool DHCP5
network 192.168.210.0 255.255.255.0
default-router 192.168.210.200
dns-server 192.168.1.200
Easwar
09-18-2014 01:44 AM
Can you execute the below command :
show ip dhcp binding
and try to change default router in a ip address that isn't in dhpch excluded address range
09-18-2014 03:46 AM
Yes the defualt route is another IP address which not in the excluded range.
Just to repharse the problem,
The DHCP is configured in the L3 switch and the config
whenever the user connect user PC connects to LAN before the PC obtains the IP address from the DHCP configured on L3 switch a IP conflict error appears, after which the PC is able to obtain the IP address and connect.
Easwar
09-18-2014 05:12 AM
Try to configure the lease with a time less that one day
09-22-2014 11:32 PM
Thanks to everyone for the reply,
Yes marcel you are right, IP conflict is reported by your client (PC)
I have changed the config as suggested by the status is the same. In fact it is worse some PC are not able to obtain IP address from the DHCP.
The config as below,
Looking forward to you suggestion..
Eash
09-23-2014 03:04 AM
Dear All,
Just to provide more information, the connectivity diagram is as below,
L3 Switch
L2 Switch
PC
When I checked the sh ip dhcp conflict on the L3 switch, the output as below
Switch-1>sh ip dhcp conflict
IP address Detection method Detection time VRF
192.168.210.32 Ping Mar 01 1993 12:02 AM
192.168.210.33 Ping Mar 01 1993 12:02 AM
192.168.210.41 Ping Mar 01 1993 12:04 AM
192.168.210.42 Ping Mar 01 1993 12:04 AM
192.168.210.58 Gratuitous ARP
09-24-2014 02:05 AM
Dear All,
When I checked the sh ip dhcp conflict on the L3 switch today the count of conflicted IP is increasing.
09-18-2014 07:25 AM
The IP conflict is reported by your client (PC) and not by the router, correct?
If yes, try to disable proxy-arp on your dhcp-VLAN:
int vlan <xyz>
no ip proxy-arp
Marcel
09-19-2014 05:25 AM
I would second what Marcel has put here, my first thought was Proxy Arp.
Try disabling and see if it resolves the issue.
