Community Member
IP Event Dampening on switchports
Hi Experts!
Does IP Event Dampening have any effect on the routing if its configured under a switchport?
Like this:
     interface GigabitEthernet1/0/6
     switchport trunk allowed vlan 10-200
     switchport mode trunk
     dampening 30 100 1000 180
Some of the vlans configured on the trunk is configured with OSPF
#sh dampening interface
1 interfaces are configured with dampening.
No interface is being suppressed.
Features that are using interface dampening:
  IP Routing
  HSRP
#sh interfaces dampening
  Flaps Penalty    Supp ReuseTm   HalfL  ReuseV   SuppV  MaxSTm    MaxP Restart
      5    1574   FALSE       0      30     100    1000     180    6400       0
Johan
Everyone's tags (3)
1 ACCEPTED SOLUTION
No, it is only used on interfaces with IP address configured to suppress routing updates if an interface is flapping.
It would only be active if you configured no switchport and put an IP address on it.
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib CCIE #37149 Please rate helpful posts.
Daniel Dib
CCIE #37149
Community Member
Re: IP Event Dampening on switchports
Hej Daniel,
So even that I get these logs, the routing is not affected?
CET: %IFDAMP-5-UPDOWN: interface GigabitEthernet1/0/6 update IP Routing state to DOWN, interface is suppressed
But I guess I should remove the dampening from our switchports...
Tack,
Johan
Yeah, remove it from the switchports.
The state would always be DOWN since IP is not active on it. In my opinion you should not be able to configure it on an interface that is not running IP.
Daniel Dib
CCIE #37149
1120
