02-27-2008 03:43 AM - edited 03-05-2019 09:24 PM
Hi all, when adding an ip helpder address, if im using vrrp between 2 distribution switches, do I set the helper address as the virtual address, or the real address of the vlan interface ?
02-27-2008 05:25 AM
Hi Carl
You should configure the IP address of the DHCP server that is providing the scope for the VLAN you are applying the ip helper-address to.
Hope this helps
Martin
02-27-2008 06:19 AM
Hi sorry, I got the question wrong, what i meant to say was what would the agent address of the vlan be, would it come from the vrrp address of the vlan or real address of the vlan ?
03-03-2008 01:30 AM
can anyone help on this please ?
