05-15-2007 11:26 AM - edited 03-05-2019 04:05 PM
I discovered the interface config command ip help-address is not available on my C870 router running
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(4)T4
How can I get my DHCP client PC requests coming in on Fa0 to be routed via my IPsec site-to-site VPN back to my home office network DHCP server?
Thanks.
05-15-2007 02:32 PM
Jacob
I believe that the issue is that interface fa0 on the 870 router is a switch port not a routed port. I believe that if you configure the ip helper-address on the VLAN interface that it should work (assuming that you have things like routing to send the request through the VPN).
Rick
05-15-2007 04:21 PM
Thanks Rick.
I'll try it on the VLAN interface.
Jacob
05-21-2007 09:32 AM
Works on the VLAN interface.
Thanks.
05-21-2007 09:51 AM
Jacob
Thanks for posting back to the forum and indicating that it works. I am glad that my answer was helpful.
Rick
