ip nat translation problem on ios
i have a router with nat overload configurated on the outiside interface. But after a few time, connectivity to outside is lost but can be reactivated with clear ip nat translation *.
I have the following in show ip nat translation before the clear :
udp 1.1.1.1:33301 10.0.0.201:33301 8.16.31.6:53 8.16.31.6:53
udp 1.1.1.1:33302 10.0.0.201:33302 8.16.31.6:53 8.16.31.6:53
icmp 1.1.1.1:7941 10.0.0.201:1410342661 8.16.31.5:1 8.16.31.5:7941
icmperr 1.1.1.1 10.0.0.201 --- ---
tcp 1.1.1.1:1151 10.0.1.211:1151 6.233.183.109:995 6.233.183.109:995
tcp 1.1.1.1:1244 10.0.1.211:1244 8.193.241.171:3126 8.193.241.171:3126
tcp 1.1.1.1:1262 10.0.1.211:1262 8.193.241.171:3126 8.193.241.171:3126
is the icmperr normal ? and the port number for icmp translation look strange too (so high??)...
i use a 1841 router with 12.4(1a) ios.
and the partial config is like
ip nat inside source route-map route-map-nat interface FastEthernet0/0.2347 overload
access-list 104 deny ip 10.0.0.0 0.0.1.255 10.0.0.0 0.255.255.255
access-list 104 permit ip 10.0.0.0 0.0.1.255 any
route-map route-map-nat permit 1
match ip address 104
any help ?
1 ACCEPTED SOLUTION
Re: ip nat translation problem on ios
I checked your IOS on CCO. It has at least one serious software defect. Before spending more time on this, I suggest that you upgrade your IOS to start with. It is a likely explanation for the portnumber (max 65535) that you noticed.
Leo
Leo
Great, resolve the lost of connection...
Thanks!
283
