Webcast-Catalyst9k
IP phone configuration difference on the switch
if we need configure the port on the switch to allow voice traffic and data traffic, we have 2 kinds of configurations:
confgiure1:
switchport voice vlan 2
switchport mode access
spanning-tree port fast
configuration2:
switchport trunk encap dot1q
switchport mode trunk
switchport trunk native vlan 1
can both these 2 work? what is the difference ?
1 REPLY
Re: IP phone configuration difference on the switch
The thing to understand is that you require a trunk port to carry more than one vlan i.e voice and data
Now the first config definitely works woth Cisco phones as they use CDP and dynamically negotiate a trunk.
The 2nd option is mostly used with other vendor phones like Avaya, nortel etc which requires us to set the port as trunk to carry both data and voice vlan
Narayan
139
