IP Phones Randomly rebooting 7942, 7971, 7941
danaledford
I have been getting reports of phone rebooting and after futther analysis they seem to be loosing power as the ports are being shutdown? Anybody seen similar issues?  Wanted to post before I call TAC, any help would be nice.
Enviornment:
IP Phone Models: 7941-42 7971
IP Phone Load 9-1-1SR1S
Switch 3560X, 3560G
Switch IOS: 12.2(58) SE2
interface GigabitEthernet0/6
switchport access vlan 40
switchport mode access
switchport voice vlan 41
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
SHOW LOG
000735: Dec 27 2011 09:51:31.421 PST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/6, changed state to down
000736: Dec 27 2011 09:51:32.420 PST: %LINK-3-UPDOWN: Interface GigabitEthernet0/6, changed state to down
000737: Dec 27 2011 09:51:34.969 PST: %LINK-3-UPDOWN: Interface GigabitEthernet0/6, changed state to up
000738: Dec 27 2011 09:51:35.976 PST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/6, changed state to up
000739: Dec 27 2011 09:51:35.976 PST: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no longer detected on port Gi0/6, operational port trust state is now untrusted.
000740: Dec 27 2011 09:51:46.855 PST: %SWITCH_QOS_TB-5-TRUST_DEVICE_DETECTED: cisco-phone detected on port Gi0/6, port's configured trust state is now operational.
23 Replies 23
Leo Laohoo
Try running TDR.
1.  Command:  test cable tdr interface ;
2.  Wait for about 5 to 7 seconds for the test to run;
3.  Command:  show cable tdr interface ; and
4.  Post the outputs please.
Hey Leo,
Sorry to interrupt this thread. I just would like to know if this command works well for subinterface.
Hey John,
Won't work on routers.
Subinterfaces?  Can't say I've tried it but depending on your switch, it should.
Cool! Thanks! I've plan to test it on one of our 6500s but was afraid it might disrupt other devices on the same main gig port.
Hey John,
Unfortunately I haven't had the chance (not allowed or BANNED) to test this on a 6500.
So if you have a Gig interface, the TDR might cause the connection to flap.  I also do not know how long it takes.  The 4500 would take 60 seconds but the 2960, 3560 and 3750 takes 5 to 7 seconds.
Please let me know how it goes so I can update the document.  Let me know your supervisor card and the blades you use please.
hey leo,
sure will do. what we're using is a 6509 with specs below. i'm also finding the right timing (some device to go down) to do this small test and will give you a feedback. is there any difference when you use TDR between FE vs GE port?
#sh ver
IOS (tm) s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Wed 16-May-07 22:09 by kellythw
Image text-base: 0x40101040, data-base: 0x42DB1650
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF9, RELEASE SOFTWARE (fc1)
Switch uptime is 13 weeks, 3 days, 9 hours, 16 minutes
Time since Switch switched to active is 13 weeks, 3 days, 9 hours, 16 minutes
System returned to ROM by reload (SP by reload)
System restarted at 04:19:45 SGT Sun Sep 25 2011
System image file is "sup-bootdisk:/s72033-advipservicesk9_wan-mz.122-18.SXF9.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509 (R7000) processor (revision 3.0) with 983008K/65536K bytes of memory.
Processor board ID TBP06200070
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
132 Virtual Ethernet/IEEE 802.3 interfaces
96 FastEthernet/IEEE 802.3 interfaces
50 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
#sh mod
Mod Ports Card Type                              Model              Serial No.
  1   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     SAL0731HMSV
  3   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     SAL0803SSFR
  4   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     SAL09232VPB
  6    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     SAL1012GNQY
  8   48  SFM-capable 48-port 10/100 Mbps RJ45   WS-X6548-RJ-45     SAL09020E8K
  9   48  SFM-capable 48-port 10/100 Mbps RJ45   WS-X6548-RJ-45     SAL0713AZE3
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  000d.659c.5ac0 to 000d.659c.5acf   1.0   7.2(1)       8.5(0.46)RFW Ok
  3  0008.7dca.83f8 to 0008.7dca.8407   3.0   7.2(1)       8.5(0.46)RFW Ok
  4  0014.69d9.c308 to 0014.69d9.c317   4.2   7.2(1)       8.5(0.46)RFW Ok
  6  0014.a981.ef0c to 0014.a981.ef0f   5.2   8.4(2)       12.2(18)SXF9 Ok
  8  0013.199c.bd38 to 0013.199c.bd67   6.1   6.3(1)       8.5(0.46)RFW Ok
  9  000c.ceb5.37f8 to 000c.ceb5.3827   5.2   6.3(1)       8.5(0.46)RFW Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  6  Policy Feature Card 3       WS-F6K-PFC3BXL     SAL1012GHF1  1.8    Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAL1012GNXA  2.5    Ok
Mod  Online Diag Status
  1  Pass
  3  Pass
  4  Pass
  6  Pass
  8  Pass
  9  Pass
Edit - It seems the TDR command for subinterfaces isn't supported.
#test cable-diagnostics tdr int g1/8.?
% Unrecognized command
TDR doesn't "understand" sub-interface.  It maybe able to see the physical interface.  Try "test cable tdr int g1/8" instead.
TDR test last run on: December 27 18:29:09
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/6     100M  Pair A     N/A                N/A         Not Completed
                Pair B     N/A                N/A         Not Completed
                Pair C     N/A                N/A         Not Completed
                Pair D     N/A                N/A         Not Completed
crb-irvine-sw2#
I will keep monitoring to post info when completed
Hey Dana,
TDR has not completed.  If you are using a 4500 the test would take 60 seconds.  If you are using 2960 or 3560/3750 then the test would take 5 to 7 seconds.  Can you please run the command "sh cable tdr int Gi0/6" again please?
crb-irvine-sw2#
What the ...?
Same results?   Can you run the commands again with another port in question?
Your switches are running 12.2(58)SE2, am I correct?
If you've got results like that, I have a strange feeling your cables from the switch is causing issues.
I am still encountering the same issue.  I have escalated to TAC.  They have a TECH dump and I am waiting for a call back. Almost 24hrs with no response after sending TECH dump.
Hi Dana,
Thanks for the update.  Have you tried changing the cable nearest the switch?
Hi Dana,
Were you able to get the resolution for your issue? I am getting the same issue in my environment too.
thanks,
Kapil
