Webcast-Catalyst9k
ip pim dm-fallback on Sup 720 or Sup II
Hi Guys,
I noticed there is no option to disable
ip pim dm-fallback
on Sup 720 or Sup2/MSFC2 on 6500. I can configure a "catch all" RP for sparse mode but would like to diable this feature if possible.
Is there a way to disable on 6500:
ip pim dm-fallback
Many thanks
Re: ip pim dm-fallback on Sup 720 or Sup II
Goncalo,
What IOS version are you running? This command was introduced in 12.2(33)SXH.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
12.2.18SXF9
Does this mean the PIM Dense Mode Fallback is enable by default on previous version to 12.2(33)SXH?
106
