Community Member
ip pim neighbor-policy not working on Nexus 7K
Hi all,
I have the following configuration on a couple of Nexus 7K:
N7K-1
interface Vlan3
  vrf member TEST
  ip address 10.139.7.252/22
  ip pim sparse-mode
  ip pim dr-priority 100
  ip pim hello-interval 5000
  no shutdown
N7K-2
interface Vlan3
  vrf member TEST
  ip address 10.139.7.253/22
  ip pim sparse-mode
  ip pim neighbor-policy FILTER-PIM-MAP
  no shutdown
ip access-list FILTER-PIM
  5 deny pim 10.139.7.252/32 any
  6 deny pim 10.139.7.252/32 224.0.0.13/32
  10 deny pim 10.139.7.252/32 any
  20 permit ip any any
route-map FILTER-PIM-MAP permit 10
  match ip address FILTER-PIM
Neighbor-policy is not working. PIM neighborship on SVI 3 is still up between Nexus 1 and 2.
Does anybody know what is wrong on the route-map and ACL?
Stefano
Everyone's tags (1)
I believe you are matching
I believe you are matching /32 in access-list whereas your SVI IP is /22
Regards Thanveer "Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Community Member
The SVI is /22 but the PIM
The SVI is /22 but the PIM packets are sourced by the physical IP address /32.
If I put /22 instead the result is the same, PIM neighborship up.
Stefano
Apply the policy in Nexus 7K
Apply the policy in Nexus 7K-1 as the source is 10.139.7.252 or change the source to 10.139.7.253 in the access-list of Nexus-7K-2
interface Vlan3
  vrf member TEST
  ip pim sparse-mode
  no shutdown
Thanveer
Please Rate if the post is helpful
Community Member
Hi Thanveer,I tried it but
Hi Thanveer,
I tried it but unfortunately it doesn't work.
I think neighbor-policy is for PIM hello received by other devices.
Stefano
Hmm true,How about this
Hmm true,
How about this command  on Nexus-7k-1
ip igmp helper-address
Causes the system to forward all IGMP host reports and leave messages received on the interface to the specified IP address.
ip igmp helper-address 10.139.7.253
Thanveer
Hello Friend, I found this,
Hello Friend,
I found this, it may be helpful to you,
N7K-1-Core1# config
Enter configuration commands, one per line.  End with CNTL/Z.
N7K-1-Core1(config)# route-map pim-policy deny 10
N7K-1-Core1(config-route-map)# match ip multicast group 239.100.10.1/32
N7K-1-Core1(config-route-map)# route-map pim-policy deny 20
N7K-1-Core1(config-route-map)# match ip multicast group 224.0.0.0/4
N7K-1-Core1(config-route-map)# int vlan 3
N7K-1-Core1(config-if)# ip pim jp-policy pim-policy in
N7K-1-Core1(config-if)# end
http://my.safaribooksonline.com/book/databases/data-warehouses/9780132883573/chapter-4dot-ip-multicast-configuration/ch04lev1sec9_html
Community Member
Hi Thanveer,the jp-policy is
Hi Thanveer,
the jp-policy is used when you want to filter Join and Prune PIM messages, but I'd like to filter Hello PIM nessages and for this the neighbor-policy option should work...
Stefano
Trying to find the solution
Trying to find the solution dear.  If you find the solution provide it here.
Community Member
Hi Thanveer,finally I got the
Hi Thanveer,
finally I got the solution.
A prefix-list has to be used insted of access-list:
ip prefix-list filter-pim seq 5 deny 10.139.7.252/32
ip prefix-list filter-pim seq 10 permit 0.0.0.0/0 le 32
  match ip address prefix-list filter-pim
Thanks for your support
Stefano
Fantastic, good to hear.I was
I was about to give a reply stating that can we check the command sh ip pim interface vlan 3, to see whether the policy is implemented or not.
Thanks to you too Friend.
Thanveer
“Acquire Knowledge and Learn Tranquillity and Dignity”
724
