IP Policy Route Map issue
Hello to everybody, I have a problem with a Cat4500 switch with Supervisor Engine V. I need to route some hosts to a destination network in a different gateway than the default. I have created an ip policy route map (route-map, ACL and applied to SVI). My problem is that the policy list is not working, traffic is still routed to the default route and also when i try to remove the policy map or the route -map or anything that has to do with the policy the switch's supervisor  restarts!!!! I have also tried to remove it after shutting the interface and the switch restarts again. My config is as follows.
interface Vlan13
ip address 192.168.13.252 255.255.255.0
ip access-group Acct in
ip helper-address 192.168.200.221
ip policy route-map NET2
glbp 13 ip 192.168.13.253
glbp 13 authentication md5 key-string XXXXXXXXXXX
ip access-list extended Net1
permit ip host 192.168.13.235 10.1.0.0 0.0.255.255
permit ip host 192.168.13.236 10.1.0.0 0.0.255.255
permit ip host 192.168.13.237 10.1.0.0 0.0.255.255
permit ip host 192.168.13.238 10.1.0.0 0.0.255.255
permit ip host 192.168.13.239 10.1.0.0 0.0.255.255
permit ip host 192.168.13.235 10.40.60.0 0.0.0.255
permit ip host 192.168.13.236 10.40.60.0 0.0.0.255
permit ip host 192.168.13.237 10.40.60.0 0.0.0.255
permit ip host 192.168.13.238 10.40.60.0 0.0.0.255
permit ip host 192.168.13.239 10.40.60.0 0.0.0.255
deny   ip any any
ip access-list extended Net2
permit ip host 192.168.13.235 172.31.0.0 0.0.255.255
permit ip host 192.168.13.236 172.31.0.0 0.0.255.255
permit ip host 192.168.13.237 172.31.0.0 0.0.255.255
permit ip host 192.168.13.238 172.31.0.0 0.0.255.255
permit ip host 192.168.13.239 172.31.0.0 0.0.255.255
permit ip host 192.168.13.235 10.31.122.0 0.0.0.255
permit ip host 192.168.13.236 10.31.122.0 0.0.0.255
permit ip host 192.168.13.237 10.31.122.0 0.0.0.255
permit ip host 192.168.13.238 10.31.122.0 0.0.0.255
permit ip host 192.168.13.239 10.31.122.0 0.0.0.255
deny   ip any any
route-map NET2 permit 10
match ip address Net1
set ip next-hop 10.10.10.160
route-map NET2 permit 20
match ip address Net2
set ip next-hop 10.10.10.100
Everyone's tags (5)
283
