11-05-2013 01:55 AM - edited 03-07-2019 04:25 PM
Sir,
I have the following conf on a 3750X.
interface Vlan250
ip address 172.16.252.10 255.255.255.0
ip policy route-map INTERNET_ONLY
access-list 10 deny 10.0.0.0 0.0.0.255
access-list 10 deny 172.16.0.0 0.15.255.255
access-list 10 deny 192.168.0.0 0.0.255.255
access-list 10 permit any
route-map INTERNET_ONLY permit 10
match ip address 10
set ip next-hop 192.168.70.2
The purpose is to direct all traffic from non-private IP to 192.168.70.2. But the route-map figure is zero. Is there anything wrong with it?
Thank you.
Solved! Go to Solution.
11-05-2013 03:51 AM
Perhaps it would help if we had a better understanding of your topology. But here is what I see so far. You have configured PBR on a vlan interface which has subnet 172.16.252.0/24. So I would expect traffic coming into that interface to have source addresses of 172.16.252.x. And your access list is denying any traffic with source address in 172.16.0.0 0.15.255.255. So is there traffic coming into interface vlan 250 whose source address is not 172.16.252.x?
Rick
11-05-2013 05:23 AM
Hello Joseph,,
Totally agree with Richard Burts
The only thing that would make this route-map to take effect is if you have all of the pivate subnet ranges (or at least some) reachable via this VLAN interface.
You know what I mean,
Otherwise you are not going to match it, to make it happen with the current setup do
access-list 13 permit 172.16.252.0 0.0.0.255
no match ip address 10
match ip address 13
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
11-05-2013 07:13 PM
If there is traffic being sent into vlan 250 that has source addresses that are public Internet addresses then the PBR that you have configured should redirect that traffic to 192.168.70.2.
Rick
11-06-2013 02:54 AM
Unfortunately on Catalyst switches from my experience the counters can't be trusted. It might have to do with that it's a hardware based platform using ASICs so counters might not always be increased as long as the traffic is CEF switched.
Daniel Dib
CCIE #37149
11-05-2013 03:51 AM
Rick
11-05-2013 05:23 AM
Hello Joseph,,
match ip address 13
Jcarvaja
11-05-2013 06:23 PM
Thanks for both.
The objective is to seperate the Internet traffic from the Internal LAN traffic while all traffic will be received on the VLAN250 interface.
Assumptions:
1) The internal LAN traffic is sourced from any of the priviate IP range only.
2) The Internet traffic should be sourced from none of the private IP range.
What I want to achieve are:
1) Let internal LAN traffice follow the routing table on the switch as usual.
2) Force received internet traffic to 192.168.70.2.
If I permit the VLAN traffic(172.16.252.0 0.0.0.255), it will break the logic above.
Any idea? Thank you all.
11-05-2013 06:35 PM
I asked some questions which you have chosen to not answer. Until you are willing to tell us whether there are devices sending traffic "inbound" to vlan 250 whose IP address is not in 172.16.252.x we will not be able to offer very good advice.
Rick
11-05-2013 06:45 PM
11-05-2013 07:13 PM
Rick
11-06-2013 01:20 AM
Thanks Rick, it seems working.
But I see the counter in "show route-map" is zero.
SW#sh route-map all
STATIC routemaps
route-map INTERNET_ONLY, permit, sequence 10
Match clauses:
ip address (access-lists): 10
Set clauses:
Policy routing matches: 0 packets, 0 bytes
DYNAMIC routemaps
Also, from "show access-list", the counter of "permit any" entry always shows zero.
Any idea why?
Thank you.
11-06-2013 02:54 AM
Daniel Dib
CCIE #37149
