Community Member
ip reachability
one IP is pinging from my desktop but not pinging from switch. what may be the problem. default route is configured in switch.
Re: ip reachability
Hi Goutam,
This is very little information about your configs.
Do you ping this IP address with source addresses that are in the same subnet?
How does your config looks like at all?
Istvan
Community Member
Re: ip reachability
yes I am pinging the IP ( 10.226.x.13 & 10.225.x.13) with source of my switch ip ( 10.163.x.254) my switch ip is in different subnet and destination ip is in different subnet. But in my firewall both IPs are accepting ICMP & Tracert.
Re: ip reachability
Hi Goutam,
Please check if the routers that are included in the traffic path all have the routes in their routing tables pointing back to your source subnet.
The icmp replies need a path from the destination subnet back to the source subnet.
Istvan
Community Member
Re: ip reachability
Thank for your help
Re: ip reachability
Hi Goutam,
Could please inform me back if my advice solved the problem :).
Thanks in advance:
Istvan
Community Member
Re: ip reachability
yes solved the problem
Re: ip reachability
OK Goutam,
I'm glad I could help you.
Cheers:
Istvan
139
