03-13-2007 07:38 AM - edited 03-05-2019 02:53 PM
For troubleshooting reason, i configured on the interface, no ip route-cache.
After troubleshooting i configured, ip route-cache.
With show run, the interface shows no ip route-cache cef. My question is, does no ip route-cache disable ip cef on the interface?
thanks
hansruedi
Solved! Go to Solution.
03-13-2007 08:01 AM
AFAIK, "IP route-cache" enables fast switching on the interfaces and the router does per-destination load-balancing. With " no ip route-cache" the router enables " per-packet " load balancing. No ip route cache disables IP CEF on the interface.
-amit singh
03-13-2007 07:47 AM
you have to use ip route-cache cef to reenable it on the interface I beleive.
03-13-2007 08:01 AM
-amit singh
03-13-2007 08:11 AM
thank's.
you confirm my suggestion.
hansruedi
