08-23-2014 05:34 PM - edited 03-07-2019 08:30 PM
Router 1 ---------- Switch 1 ---------- Switch 2 ---------- Router 2 ---------- Router 3
Router 1 (main)
interface 1 - 10.110.47.254
interface 43 - 10.110.43.254
Router 2 (DSL CO)
vlan 43 - 10.110.43.207
atm0.1 - 10.110.125.1
Router 3 (DSL CPE)
vlan 150 - 10.110.150.1
atm0.1 - 10.110.125.2
currently I have the following ip route statements:
Router 1
10.110.125.0 255.255.255.0 10.110.43.207
10.110.150.0 255.255.255.0 10.110.43.207
Router 2
0.0.0.0 0.0.0.0 10.110.43.254
10.110.150.0 255.255.255.0 10.110.125.2
Router 3
0.0.0.0 0.0.0.0 10.110.125.1
The problem is that I can't ping the far side CPE (10.110.150.1) from the Main router or the CO router. I can ping back to the Main router from the CPE router. This makes me think the 10.110.150.0 255.255.255.0 10.110.125.2 statement isn't doing anything. Can anyone identify the problem here? Thanks
08-23-2014 06:02 PM
10.110.150.0/24 is part of vlan 150. Is vlan 150 configured correctly and it is up and running?
Has the interface been added to vlan 150?
08-23-2014 06:13 PM
Here is part of the config from the CPE:
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
ip address 10.110.125.2 255.255.255.0
cdp enable
pvc 8/35
encapsulation aal5snap
interface FastEthernet0
switchport access vlan 150
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan150
ip address 10.110.150.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.110.125.1
When I do a: sh int vlan150, it says:
Vlan150 is down, line protocol is down (so, no, it isn't up)
08-23-2014 06:21 PM
So, couple of items to check
1-Did you create the layer-2 vlan
config 1
vlan 150
name test-vlan
exit
also, I see interfaces 0-3 are part of vlan 150. Is any device (PC, laptop, printer, etc) connected to any of these ports?
sh ip int bri fa0 or fa1
If there is no device connected to one of these ports with an IP the vlan will not come up
08-23-2014 06:36 PM
These units are just in a test environment right now. There is not anything plugged into Ethernet ports 0-3.
Regarding the Layer 2 question... are you asking if I created vlan 150 on the switches? The CPE is the only device that has vlan 150.
08-23-2014 06:43 PM
Then if there is no device connected to any of the ports, the vlan interface is not going to come up. It will stay down until a device (PC, laptop, etc..) is connected to one of the ports. For test purpose, you can connect a laptop to one of these ports and give it an IP address in 10.110.150.0 range and see if the vlan interface comes up. sh ip int bri vlan 150
Correct on the same device where you have the layer-3 interface
nterface Vlan150
ip address 10.110.150.1 255.255.255.0)
you also need to create a layer-2 interface.
08-23-2014 07:01 PM
If I use the "no autostate" command, will it force the interface up and allow me to ping/access it?
Also, I am confused about the Layer 2 vlan requirement. Are you saying that I need to add the commands you provided to the CPE Router? If so, can you please explain why? Thanks
08-23-2014 07:07 PM
You can try the "no autostate"command. The other way you can test is by creating a loopback interface and move the ip from vlan 150 to loopback and test
config t
inter vlan 150
no ip address
int lo0
ip add 10.110.150.1 255.255.255.0
no sh
then sh ip int bri lo0
now try to ping this IP from router 2.
08-23-2014 07:20 PM
I will try this and report back. It probably won't be until Monday though. Thanks.
08-25-2014 03:14 PM
Yes, the "no autostate" command worked. I can now access the CPE successfully (even when nothing is connected). I also applied the command to the CO side in case we are ever in a situation in the work environment where the CO side may be disconnected and we are on the CPE trying to verify the connection.
One more thing... (and please excuse my ignorance) while the connection does work correctly inside my location (main router), there is no access to anything other than the LAN side of the CO from the outside. I assume the other routers (at other locations on our WAN) don't know the route. If I'm on the CPE end, I can get to our main router, but nothing else. I may be getting out, but nothing knows how to get back in?
08-25-2014 04:25 PM
Glad to hear that the "no autostate"worked for you. And yes, that is correct the router in other location most likely don't have the routes to get back in.
08-25-2014 05:13 PM
What are my options to get the route into the other routers?
We have several of these Cisco 888 DSL routers connected at different sites. Most of the other 888 units can be accessed from all the other locations in the WAN (each location has it's own main 2911 router). I have tried to compare any static routes in the routers, but I don't see any. So how can the other 888's be seen from other locations? Thanks.
08-26-2014 12:34 PM
I figured it out. I just needed to add the "redistribute static" command.
