Community Member
IP route
Hi all,
I have a router with the following configuration: ip route 0.0.0.0 0.0.0.0 Serial0/1/0:1 172.16.200.153
ip route 0.0.0.0 0.0.0.0 Serial0/0/0:1 172.16.200.157
show ip route
<Output Omitted>
Gateway of last resort is 172.16.200.157 to network 0.0.0.0
show ip route static
S* 0.0.0.0/0 [1/0] via 172.16.200.157, Serial0/0/0:1
[1/0] via 172.16.200.153, Serial0/1/0:1
Because I have two default routes does that mean the router is using both for internet traffic even though the gateway of last resort is just one?
Thanks in advance
Hall of Fame Super Silver
Re: IP route
Hello Hipolito,
yes both default routes are used you can see this on the sh ip route
both are listed so both are installed and used.
Hope to help
Giuseppe
Community Member
Re: IP route
Thanks a lot Giuseppe
Re: IP route
Giuseppe,
Would this type situation be a load balanced scenario or failover?
John
HTH, John *** Please rate all useful posts ***
Blue
Re: IP route
John, both routes will be active in the routing table, so they would both be utilized. The manner in which you share the traffic load across the two links would depend on what kind of load balancing you are using.
Victor
Re: IP route
Victor,
As in glbp, or more like the type of routing protocol you're using like bgp?
Thanks!
John
Hall of Fame Super Blue
Re: IP route
John
As in per packet or per destination load balancing.
Jon
Blue
Re: IP route
HEY HEY HEY!!!! >:-(
Don't you be steppin' in my space...Mr. Man!!!
Re: IP route
Sorry Victor couldn't resist :-)
Besides, since when has your name been Giuseppe as in
"Giuseppe,
Would this type situation be a load balanced scenario or failover?"
Jon
Re: IP route
LOL!
Blue
Re: IP route
The routing protocol will discover 2 equal cost paths and place them both in the routing table (forget about EIGRP variance for now).
What I was referring to is wether you have per-packet- or per-destination-based load sharing configured.
With per-packet load balancing, each path is utilized alternately on a packet by packet basis. This utilizes both links pretty evenly, but you may get an issue with a disparity in delay and packets being received at the distant end out of order.
With per-destination, it is as the name suggests; each source-destination flow will be examined and one path selected based on that.
Victor
Re: IP route
hmmmm....do you have a link to describe how to configure per-destination load sharing?
Re: IP route
John
I could tell you but then Victor will have a go at me so i can't i'm afraid :-)
Jon
Blue
Re: IP route
That's more like it...damn it. ;-)
Blue
Re: IP route
LOL! Thanks :)
John
Blue
Re: IP route
John:
You're welcome.
Jon:
I rated the post in which you show that you have finally come to your senses and realized that I am someone you should be afraid of!
LOLOL
Victor
Re: IP route
Typical
I spend half the day providing some of my best technical advice to multiple posters and the only rating i get is for this !!
I am afraid Victor, very afraid....
Re: IP route
I rate you all the time! :)
Re: IP route
John
Indeed you do and it is much appreciated. My comments were really directed at Victor as i hope you realise. NO offense intended.
Victor - see what problems you cause :-)
Jon
186
