IP Routing and CEF both Required to apply policy on interfaces?
One of my access switches wont allow me to set the policy on it's user interfaces
sa-us-oak-001(config)#int gi 3/1
sa-us-oak-001(config-if)#service-policy input voip
The policy voip cannot be attached to the interface Gi3/1 since it has 'set' actions. IP Routing and CEF Switching are required for 'set' actions to be effective.Please enable IP routing and CEF switching.
All of my other access switches have no problem with this configuration and none have ip routing enabled. They do however have ip cef enabled where as
sa-us-oak-001 does not;
sa-us-oak-001#sho ip cef
%IPv4 CEF not running
My question is; Should I be able to just configure ip cef globaly, then apply my policy to the interfaces or am I missing something else?
--Mike
Also, here is my QOS configuration
#Access-list with Snom SIP & RTP
ip access-list extended voip-traff
permit udp any any range 5060 5061
permit udp any any range 10000 20000
#class-map named ipphone & match acl voip-traff:
class-map match-any ipphone
match access-group name voip-traff
#Policy map named voip, match class-map iphone:
policy-map voip
class ipphone
set dscp cs5
#set interfaces to police policy-map voip:
interface-range gi 0/1 - 48
#enable qos globally:
mls qos
#qos on 4500
#map out QOS to COS-DSCP
mls qos map cos-dscp 0 8 16 24 32 46 48 56
The image is: cat4500-ipbasek9-mz.122-31.SGA9.bin
1 REPLY
VIP Super Bronze
Re: IP Routing and CEF both Required to apply policy on interfac
Mike,
By default, CEF is enabled globally on the Catalyst 4500 series switch. No configuration is required.
To reenable CEF, issue "ip cef" globally
Reza
985
