IP Routing Error
everestmountain
I am receiving an "IP routing not enabled error." How can this be fixed?
cisco_lad2004
Level 5
Level 5
try
conf t
ip routing
becareful, if you have a gateway set you will loose remote connectivity to teh box.
Sam
5 Replies 5
cisco_lad2004
Level 5
Level 5
try
conf t
ip routing
Sam
I can't believe this wasn't covered on the CCNA certification exam.
brace yourself, it does not stop there...and that is the beauty of it :-)
What is go good about not learning the fundamentals on the CCNA exam?
What I mean is that the learning process in this filed has no limit, be it for exams or real life.
