10-31-2011 04:31 AM - edited 03-07-2019 03:08 AM
For intervlan routing, Is 'IP routing' command enabled by default on a 6500 series switches based on the IOS?
and on 3750 switches, do we need to enable the "ip routing" command manually for intervlan routing?
Request to please calarify.
10-31-2011 04:44 AM
You need to manually enable routing on the 3750 switch by using the ip routing command. Even if IP routing was previously enabled, this step ensures that it is activated.
Switch(config)#ip routing
On a 6500 series switches IP routing is by default enabled.
Please rate the helpfull posts.
Naidu.
10-31-2011 04:46 AM
For your information regarding 6500...
IP routing is enabled by default. However, IP routing does not work if what must be routed is not configured on the switch. This is because the switch has a built-in router.
IP routing cannot be disabled on the Supervisor 720 (Sup 720). However, the ports can all be configured as Layer 2 (L2) ports. The ports can all be L2 access ports in particular VLANs, which can accomplish the desired effect.
The no ip routing is a classical IOS command used to disable IP routing on routers. This command is usually used on low-end routers, on Cat 6k this command doesn't make sense hence, command will not be saved across reload if entered. When you enter the no ip routing command you may get a console message: "Cannot disable ip routing on this platform"
Note: When IP routing is enabled, the cpu resources are wasted in performing the Layer 3 (L3) computation. Hence when L3 functionality is not needed, do not configure it.
Naidu.
