IP SLA commands missing?
Hello all,
I've got two routers, Cisco 2911's with 15.1(4)M1 on one and 15.0(1)M5 on another.
I'm trying to set up ip sla for vrrp tracking but the commands seem gimped?  I don't even have an option for ip sla <operation number>.  All I've got is ip sla responder/server/key-chain.
I must be missing something?  Something I gotta turn on?  A different command?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Kyle
It is probably your feature set (license) you are running. For example the IP Base in 15.1 only supports the ip sla responder commands whereas the DATA license supports all ip sla operations.
So you may need a license upgrade depending on what you are currently running. Which license you need depends on the other features you need and for this yoiu need to use Feature Navigator -
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
just go to the above link and choose "Searcb by platform" select the 2911 and then enter the IOS you have in the drop down boxes and a feature set and it will show which features are supported.
Jon
1 REPLY
Kyle
Jon
1429
