ip sla enable reaction-alerts on 2960X
Jacob Berger
Level 2
Level 2
copied config from 2960S
cannot set "ip sla enable reaction-alerts" on new switch:
  WS-C2960X-24PS-L   15.0(2)EX3            C2960X-UNIVERSALK9-M
get:
comp-room-2#ip sla enable reaction-alerts
% Invalid input detected at '^' marker."
what am i doing wrong
thanks
8 Replies 8
Sandeep Choudhary
Hi Jacob,
First go to config mode and the run this command:
comp-room-2# Config t
comp-room-2(Config)# ip sla enable reaction-alerts
Try this.
Please rate helpful posts.
sorry
i pasted the wrong text
this is what i get
comp-room-2(config)#ip sla enable reaction-alerts
the marker on the word enable
when i do ip sla ?
i get
comp-room-2(config)#ip sla ?
  key-chain  Use MD5 Authentication for IP SLAs Control Messages
  responder  Enable IP SLAs Responder
Hi Jacob,
To use Cisco IOS IP Service Level Agreements (SLAs), the switch must be running the LAN Base image.
I think ur image did not support this feature.
Paste the sh version output or  to check if your Image supports IP SLA or not: Please check here: http://tools.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
comp-room-2#sh ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2)EX3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 11-Sep-13 02:04 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.0(2r)EX, RELEASE SOFTWARE (fc1)
comp-room-2 uptime is 1 day, 1 hour, 6 minutes
System restarted at 13:32:26 UTC Wed Nov 13 2013
System image file is "flash:/c2960x-universalk9-mz.150-2.EX3/c2960x-universalk9-mz.150-2.EX3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-24PS-L (APM86XXX) processor (revision A0) with 524288K bytes of memory.
Processor board ID FOC1741S091
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 64:E9:50:C9:38:00
Motherboard assembly number     : 73-14193-03
Power supply part number        : 341-0528-01
Motherboard serial number       : FOC17403J4S
Power supply serial number      : DCB173273ZU
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C2960X-24PS-L
Daughterboard assembly number   : 73-14200-03
Daughterboard serial number     : FOC173917SL
System serial number            : FOC1741S091
Top Assembly Part Number        : 800-38007-01
Top Assembly Revision Number    : A0
Version ID                      : V01
CLEI Code Number                : CMMLR00ARA
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C2960X-24PS-L   15.0(2)EX3            C2960X-UNIVERSALK9-M
anyone?
Hi Jacob,
I did nt find any exact reaction.
Please try to update the IOS.
This IOS hav many bugs.
https://supportforums.cisco.com/thread/2236950
Hope it helps.
SW-01#sh ver | i 15.2
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E, RELEASE SOFTWARE (fc3)
* 1 28 WS-C2960X-24PS-L 15.2(2)E C2960X-UNIVERSALK9-M
SW-01(config)#ip sla enable
SW-01(config)#ip sla ?
What else can I try to be able to do 'ip sla enable reaction-alerts' on 2960X?
Ricky
I know it's so late but I'm just letting you know.
You may hitting bug CSCtb35715 .
