Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hi All,  am using Cisco 9200 switches and assigned management IP as under mentioned. I have some other servers which are using the same IP network and with VLAN 10 , but am not able to ping switch from my laptop configured with VLAN 10 . Can you plea...
uni1389 by Level 1
  • 19 Views
  • 0 replies
hi all,before on this switch (nexus 7000) i could do a "wr" or "copy run start" no problem but now i get thiswr[########################################] 100%Configuration update aborted: request was abortedthanks,rob
Acabei de criar uma vlan, atribuí-la a uma porta em nosso 6509, atribuí à vlan um endereço IP e quando eu disparo o comando, show int vlan 31 ele diz que a vlan está administrativamente inativa. Não consigo descobrir o que está acontecendo aqui? emit...
ftoprakw by Level 1
  • 83 Views
  • 1 replies
Hello,At my home, I had an 8 port 2960G switch die after a power outage today.  I replaced it with a ISR 1921 that has an 8 port ESM.  It's been a very long time since I messed with configuring ESMs...  My plan was to just copy over all of the switch...
Good morning friends,I have created two extended ACLs for in and out of my int vlan and applied it under int vlan for both directions inbound and outbound. I have created ACLs entries like this.For int vlan no. Out1 permit ip 10.1.0.0 0.0.255.255 hos...
