IP SLA Fail back question
If my ISP were to go offline and the route that I am tracking is removed, is there a way to set a time before it can return to the main line? I know I could simply pull the cable if the line goes down but I am wondering if there is a way to automate it. For example ISP 1 goes down and ISP 2 takes over. Can I say that ISP 1 must be back up for 1 hour before switching back?
Re: IP SLA Fail back question
Yes,
After you create you IP SLA instance you create you track rtr's
under the following
track 1 rtr 1
delay down (seconds) up (seconds)
this should be the value you are looking for.
Bronze
What method are you using to track? And are you running any routing protocols? BGP can suppress a route for a specified time period if it goes down then back up.
With object tracking, I believe the maximum abmount of delay you can introduce is 180 seconds.
HTH,
Craig
I am not using any routing protocols and I am using icmp-echo for tracking. I have 2 ISPs and one is pretty much just on standby unless the main goes down. For example
ip sla 1
icmp-echo 4.2.2.2
frequency 3
ip sla schedule 1 start-time now life forever
track 1 rtr 1 reachability
ip route 0.0.0.0 0.0.0.0 1.1.1.1 track 1
ip route 0.0.0.0 0.0.0.0 1.1.1.2 20
So I guess the question is with this config, is there a way to prevent the main from coming back online for a period of time?
Bronze
The other poster had the right answer for you:
delay down
But it only has a limit of 180 seconds.
HTH,
Craig
Yes,
as previously posted
Taking your example
ip sla 1
icmp-echo 4.2.2.2
frequency 3
As mentions only up to 180 seconds
871
