IP SLA failover config
I'm new to networking, and I need some help on IPSLA failover config.
I have a router that I have recently configured ( thanks to all of you for the assistance ), and now I need to configure it for IPSLA failover.
Request:
I have 3 int connections, g0/0 (LAN), g0/1 (WAN), and ATM0/0 (DSL). I would like to configure one of those (the LAN & DSL) int to take over after the other has failed .The router is Cisco 1941.
How would I configure my router for failover?
Would I create 2 route-maps?
route-map int g0/0   <---------- is this right?
match ip add 1
match interface int x/x   <----- what would that be?
route-map DSL   <------ would that be ATM0/0 or DSL?
match ip address 1
match interface dialerx
create the ACL 1
access-list 1 permit x.x.x.x y.y.y.y  <------- (where x.x.x.x is the subnet I want to be natted and y.y.y.y is wildcard mask)
create 2 dynamic nat entries
ip nat inside source route-map int g0/0 interface int g0/0 overload   <---------- is this correct?
ip nat inside source route-map DSL interface dialerx overload
create the ip sla action
ip sla 1
  icmp-echo x.x.x.x.x where x.x.x.x is the next-hop on serial link   <------------ totally clueless here
  timeout xxx    how many time without a response so ip sla fails and tracked object is down  <-------- what is the standard default setting?
  frequency xxx  how often you send the ping   <-------- what is the standard default setting?
  exit
ip sla schedule 1 start-time now life forever  start the ip sla action
track 1 rtr 1 reachability  <---------- do I need to create this tracking object?
create 2 default routes, the backup one has an AD higher than primary and you gonna track the primary
ip route 0.0.0.0 0.0.0.0 int g0/0 track 1
ip route 0.0.0.0 0.0.0.0 dialer x 100
Thanks.
- Joey
286
