Community Member
IP SLA ICMP Echo support Catalyst 3560X/3750X
can someone clarify if ip sla icmp echo operation is supported in catalyst 3kx switches (ip services)? on the configuration guide, commands are available, but on the feature navigator, i can't find the feature, only ip sla video operation. i don't have a device to test on here. thanks!
Silver
Greetings,
Yes, Catalyst 3560-X/3750-X with IP Services license can be IP SLA initiator for ICMP Echo operation. LAN Base / IP Base licenses can only act as responder.
Seems Feature Navigator needs updating for the -X series, if you check with platform 'CAT3750E' it's listed.
Hope this helps,
/Phil
Community Member
yeah, that's why i wondered why on the feature navigator its not listed since catalyst 3ke and 3kx have the same universal ios. i have opened case to helpline and the response was "no it can't support based on feature navigator". i don't have a switch to test here.
1886
