IP SLA not putting route in table
I set up IP SLA for icmp-echo on an IP that would then be tracked by a static route. The IP SLA summary showed this as succeeding but the route is not in the routing table.  I believe this should be all relevant configuration and output. The IPs and naming have been altered so apologies if I end up missing something. The idea behind this is that when an IP is active at this site (active/standby site) the IP SLA tracked route will kick in and be redistributed into BGP and advertised to the 2 routes that have the GLBP address of 10.30.30.8. BGP conifguration not inlcuded since the issue seems to be with the IP SLA config (no static route in table).
track 5 ip sla 1 reachability
delay down 3 up 3
ip sla 5
icmp-echo 10.10.10.10 source-ip 10.30.30.11
vrf Customer1
ip sla schedule 5 life forever start-time now
ip route vrf Customer1 10.10.10.0 255.255.255.0 GigabitEthernet0/0/0.5 10.30.30.8 track 5
interface GigabitEthernet0/0/0.5
encapsulation dot1Q 5
ip vrf forwarding Customer1
ip address 10.30.30.11 255.255.255.0
end
ASR1001#show ip route vrf Customer1
Gateway of last resort is 10.30.30.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 10.30.30.1, GigabitEthernet0/0/0.5
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.30.30.0/24 is directly connected, GigabitEthernet0/0/0.5
L        10.30.30.11/32 is directly connected, GigabitEthernet0/0/0.5
ASR1001#show ip sla summ
IPSLAs Latest Operation Summary
Codes: * active, ^ inactive, ~ pending
ID           Type        Destination       Stats       Return      Last
                                           (ms)        Code        Run
*5           icmp-echo   10.10.10.10     RTT=1       OK          25 seconds ago
Green
Ben,
This looks wrong
ip route vrf Customer1 10.10.10.0 255.255.255.0 GigabitEthernet0/0/0.3 10.30.30.8 track 5
should be
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Re: IP SLA not putting route in table
Sorry, that was a copy paste error.  I checked and the route statement has the correct subinterface tag in the configuration. I'll edit the post.  I copied the route line from the other site device which has the interface tagged as .3, then I altered the gateway IP for security. VRF and destination IP/Mask are the same for the routes at each site but the gateway and subinterface are different.
Found it.
should be
track 5 ip sla 5 reachability
243
