You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
IP SLA support for C4506 switch
Hello Everybody,
I was looking for a IOS which can support IP SLA on our C4506 switch. Currently we have 12.2(25)EW installed and need one IOS of the same 'Basic L3' category which could support IP SLA.
Arabinda
  • LAN Switching and Routing
Re: IP SLA support for C4506 switch
You should check Cisco IOS Feature Navigator Tool at http://tools.cisco.com/ITDIT/CFN/
Search by technology or Platfrom for IP SLA feature to get a complete list of software that support IP SLA.
For instance this image supports IP SLA along with other Enhanced L3 features
cat4500e-entservicesk9-mz.122-53.SG1.bin
However this is an Enterprise Services Image. IP Base Images do not support IP SLA, they only support IP SLA Responder feature.
Thanks & Regards
Zeeshan Sanaullah
Thank you Zeeshan. The real problem is the SG series IOS, or the enterprise class IOS has a problem that, they do not support EIGRP stub networks. Recenlty we upgraded, but one of our eigrp stub network lost connectivity.
They do support EIGRP Stub Routing according to the Feature Navigator.
The image I mentioned also does support EIGRP Stub Routing.
Thanks & Regards
Zeeshan Sanaullah
Hello Zeeshan,
Sorry I meant the software should not feature EIGRP stub routing, since we have few stub branch office connected. So searching for a software with IP SLA, PBR with multiple tracking options, but no EIGRP stub routing.
Unfortunately in the cisco site i could not any IOS with enterprise version, hope this requires additional license.
Arabinda
Silver
Hi Arabinda,
I'm afraid the PBR with object tracking is not supported on any of the ISO releases/feature sets at this moment.
http://www.ciscosystems.com.ro/en/US/docs/switches/lan/catalyst4500/release/note/OL_5184.pdf
Hope this helps, rate if does
Krisztian
908
